New 94 urs4 sluggish problem... videos!
#11
Replied! Sorry if I came off rude or upset! No hard feelings. Youre awesome for helping so much!
I checked the moisture trap and it seems tight. I did a boost leak test tonight and everything seems tight. Only issue I had was trying to listen over my boost leak testers hiss...
I was driving home tonight and actually put my foot to the floor and it woke up. I guess I'm used to my stage 2 B5 S4. I still seemed a little slower but it IS stock... for now.
Any chip recommendations? Or DIY chip burning? I'm looking for something cheap right now since I just sold my other B5 S4 to put a down payment on a house so money is kinda tight for a few weeks!
If it's one of those things where it can't be done "right" for cheap could you elaborate?
Thanks again!
Thanks again!
#12
There are chip sets out there for cheap. Even chipped ECUs with the 3.0 Bar upgraded MAP sensor, often for under $500. Typically good for 270-280 hp (which is as far as you can safely go with out entering the slippery slope of bigger turbo, exhaust manifold, bigger injectors, etc).
I left you a long reply on the S2Forum private mail.
#13
Honestly, if I could figure out an EMS and a cheap/reliable exhaust manifold, i'd probably go with an HX35 or HX40. They're bulletproof and make gobs of power. So far though driving this damn car has me at my wits end! I've been trying to track down a mid boost misfire. I used an adjustable spark plug tester. Found that coil 3 was "weaker" than all the rest so I swapped it out with a "good" coil and the damn thing misfires worse than the original one. Facepalm.
I'm gonna try and pick up a few coils tomorrow as well as an extra POS. This ignition system is a damn joke. Anything else out there that's more reliable yet still fairly cheap? I've seen the 1.8t swap but wasn't sure exactly whats best these days. I managed to wrangle a few bucks from the fiance out of our "house fund". I just can't stand it anymore. I haven't been able to do a full boost pull yet since I've owned the damn thing. On top of that I get very little time to dick with it. I'm tired of wasting time on it with little to no change.
#14
When my original coils/POS starting acting up 2 years ago I ordered the LS2 kit from EFI Express for ~$400. It took about an hour to pull the old stuff out and hook up the new kit. I'm sure it's not bulletproof, but it seems to work well with my MTM stage 1+ setup, and no yearly coil/POS issues.
#15
You can't expect miracles when you replace a used part with a used part. The only good news is you learned how to swap in a "new" coil.
The Apikol sets are around $375. Apikol is in the Denver area.
audi5500
01-11-2010 08:25 AM
MOBlueTT
04-30-2005 08:59 AM
Jim Bush
07-09-2003 05:38 PM
