No power from Cigarette Lighter outlet - '95 S6
#13
#14
Sometimes I get this problem but I simply adjust my wire, shuffling it from side to side usually does the trick!
Car service
Car service
#15
This sometimes happens to me, I shuffle my wire from side to side and this usually does the trick with me.
Car service
Car service
#16
This lighter socket is larger than the modern lighter/power sockets and is easily shorted if the power plug is allowed to **** slightly, which, of course, will send you back out to change that fuse.
Something from an '06 Audi should be new enough and retain the red lighting if you get the entire assembly of the lighter socket and plastic light surround. It will fit the hole perfectly, although you may have to modify your wiring for the plug. Just using generic insulated spade connectors is easiest.
#17
I'll keep an eye out for a newer assembly as a future project. Meanwhile I have not had any trouble - I have run a GPS and charged my phone since. I think my AC inverter is going to stay in my wife's car though.
TheMidnightSun
04-18-2005 08:44 AM
Avantussy
Audi 100 / A6 (C4 Platform)
11-23-2004 10:18 PM
