OK, gotta figure out where the front suspension "klunking" is coming from.....need help........
any tips from you guru's? I'm going to do some investigation today. I guess I'll be checking for bad subframe bushings, swaybar bushings and anything else that can be causing this. Any tips on what to look for are greatly appreciated.
4Driver4.....sorry I could't stop by this week.....work sucked big time.
It almost seems like it is coming from the rack, it especially does it right after I start the car, drive away and I am turning the wheel. One clunk and then it is gone until next time.
<ul><li><a href="http://www.sjmautotechnik.com/trouble_shooting/susp.html#steerplay">Rattling, clunking or popping noise when you first turn the wheel</a></li></ul>
only klunks at low speeds (like pulling into raised driveway)with the wheel turned.
checked and tightned all bushings, control arms, sway bar bushings, tie rods and still does the same thing.
i guess the next step is to adjust the rack.
would this mean that the rack needs replacing?
FMIC
Dual oil cooler set-up
Converting stock cooler to PS cooler
Control Arms
Strut Mounts/Bearings
ECS spacers in rear
Fabbing Camber plates
Coolant Flush
Power Steering Flush
Stromung
Control Arms
ECS spacers in rear
Coolant Flush
Stromung
