ok, so it appears my front brakes aren't working...ideas?
my rear wheels get absolutely filthy in much shorter time periods than they should, while the fronts stay very clean. and the car does not stop well. If I really slam the brakes hard, the car does exhibit some brake dive, and there is a small amount of brake dust on the front wheels, so I believe they do work to some extent. but in normal driving, I think it's just the rears that are working.
I have not yet bled the brakes, and they need it badly. the fluid is molasses color. planning to do that on friday when I swap over to the snowtires. but this seems to be more of a problem than that will fix.
maybe the proportioning valve is shot? any other things to look at? thanks
corrosion in the caliper pistons. You could also have a siezed rear proportioning valve that is giving too much bias to the rear brakes.
I really think that you should not drive your car until you get this fixed.
I used 10 PSI with my Motiv I think. Probably 15 when I was trying to figure out why the rears were bleeding so slowly!
for a car that was owned by an audi tech, this thing sure wasn't maintained all that well. The scary thing is, nick and I drove it from Milwaukee to Boston as it is now. It'll stop alright if you jump on the brakes, it's just under light braking that the rears seem to be doing all the work.
Anyway, I've always had good luck with the two-man brake bleeding system (I don't own a pressure bleeder). Will that work on these cars? I do know what I'm doing, I used to bleed the brakes in my old GTI every morning at the track. Also, is it obvious how to jam open the prop valve? Thanks
Here is a shot of the pressure regulator for the rear brakes. With the drill bit in place the valve should be open. You don't need to do the other steps just to wedge it open, but if you're questioning the bias it'd be worth adjusting it to spec while you're at it.
<a href="http://www.boost-instruments.com/propvalve.png"><img src="http://www.boost-instruments.com/propvalve.png"></a>
You can borrow my pressure bleeder if you want.
