ok, so the car started like a champ this morning. pulled codes - 2113 - cam pos sensor
#11
You might want to explore that route... otherwise germanautoparts has the correctly mounted part for ~$200 USD. The alternative is to get the one listed below for less and pop rivet it in yourself!
A gentlemen on Audifans obtained a rotor arm for a Volvo from about 1988 - uses exact same hall device - for cdn$50. Removed it and placed it on to mounted bracket with SS pop rivets and it works!<ul><li><a href="http://www.germanautoparts.com/Volkswagen/Passat/EngineElectrical/45/3">http://www.germanautoparts.com/Volkswagen/Passat/EngineElectrical/45/3</a</li></ul>
#15
Also, there is a replacement which is a virtual copy of the CPS for only $13 from Cheng Yang in N.Y. at 801-938-4722 or www.bbautomacao.com.Exact same size,no fitting to do.HTH
Don
Don
#18
it is physically different, however the mounting holes are in the same location, but the vane opening is 2mm further ahead. Since there is a lot of play in how you position the CPS and the electrical characteristics are the same both units should be a suitable replacement.
abcspecialist
12
11-20-2018 05:35 PM
agrandy
06-09-2008 05:26 AM
allroad(s) lead 2Gavin
Audi allroad
9
12-02-2007 11:50 AM
