OKADA PROJECTS // Seen these "High Output" coil packs before?
Not affiliated with this company, but when i was in the B6 world, this was one of the few "high output" coil pack upgrade options we had. So this would have to be paired up with the 034, Apikol, or Dave's DIY 1.8T harness.... unfortunately the coil packs are RIDICULOUSLY expensive...
Someoen out there's gotta be rich (or crazy) enough to give these a dyno run.... =)
Features:
- 100% secondary current (Spark Amperage) increase
- 4 Times Spark Energy Increase for the initial spark discharge
- Easy installation. Only replace stock coils to Plasma Direct.
- Compatible with all OEM components
- Compatible with OBD-II (On-Board-Diagnostics)
"PLASMA DIRECT (PAT)
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car."<ul><li><a href="http://www.okadaprojects.com/usa/products_direct.htm">OKADA PROJECTS</a></li></ul>
Features:
Basically what those coils are doing is called CDI, Capacitor Discharge Ignition:
<a href="http://en.wikipedia.org/wiki/Capacitor_discharge_ignition">wikipedia</a>
MSD makes a nice add-on product that allows you to drive a standard coil via CDI. It gets a little pricey for coil on plug systems like our cars since you need one channel per cylinder, but if you dont mind wasted spark this would get the job done:
<img src="http://static.summitracing.com/global/images/prod/large/msd-62153_w.jpg">
<a href="http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D62153&N=700 +115&autoview=sku">$560 at summit racing</a>
arjun90
05-05-2015 05:40 AM
bwells1200
03-03-2012 09:42 AM
