Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
removing guage cluster
Old 10-24-2005, 01:26 PM
New Member
ncskiier's Avatar
Default removing guage cluster
This has probably been covered but my search did not bear fruit. I need to remove my guages to change out the bulbs. Is there a tutorial available somewhere? Or any helpful advice?
Old 10-24-2005, 01:30 PM
|skolnick's Avatar
search for "removing instrument cluster"
Old 10-24-2005, 01:44 PM
S6 4RiNGS's Avatar
Default Remove the 2 screws under the trim piece at the bottom of the IC...
then remove the 3 screws holding the IC in place to the dash. But before you remove the 3 screws make sure you put a towel over the steering column shroud, cause it will scratch easily!!! Then uinplug all the wiring if you cant access it by just reaching around and behind!
Old 10-24-2005, 01:45 PM
S6 4RiNGS's Avatar
The 5 screws are all Philips Head!
Ninetyfive90Quattro
03-17-2006 09:20 AM
AudiTeaT
01-29-2006 06:14 AM
parkpy
10
04-10-2005 08:48 AM
Mark - Steve's bro'
Audi 100 / A6 (C4 Platform)
09-18-2003 09:30 PM
Stang Guy
12-18-2000 06:22 PM
Quick Reply: removing guage cluster
