S6 Plus Wiring Diagram
<center><img src="http://pictureposter.audiworld.com/52091/img_3046.jpg"></center><p>Anyone european owners have a wiring diagram? I bought the xenon headlights from a S6 Plus and trying to wire up the lamp control module.
Here is a teaser pic...
Thanks.
Thanks.
The connector from the ballast has 4 wires
red - 12v constant
yellow - switched 12v from low beam
brown - ground
black - lamp control module
Its the black wire that I'm trying to figure out how it connects to the LCM so I don't get the burned out bulb light on Autocheck display.
brown - ground
This is in addition to the connector on the back of the headlight (see pic)...
<center><img src="http://pictureposter.audiworld.com/52091/img_3007.jpg"></center><p>
that has terminals for high beam, fog, city and ground.
Well...they are not cheap...
They retail for 2,000 euros new and are only available from the dealer (Europe), I bought them used from ebay.de for less than half that. Quite a bit more than other options out there, but I wanted the e-code xenons (OEM) rather than DOT with a HID kit.
Re: S6 Plus Wiring Diagram
You have 4 wires in the connector
Yellow - Trigger - connect to low beam wire (yellow) in the existing harness
Red - +12v fused (I used 10amps)
Brown - Ground
Black - LKM Sense wire goes to +12v when the lamp fails to ignite (I taped it)
HTH
Brown - Ground
HTH
Where on the LKM does the black wire go?
Hi Nick;
The LKM module for the S6 and the S6 Plus is the same part number, but I can't figure out where or how this attaches. This is why I'm looking for a S6 Plus wiring diagram.
Sean Douglas - aka quattro20v
