Secondary or Auxillary Fan running all the time
#12
Well, if you are going to let this little connector defeat you, perhaps you are beyond help. : - ) Just buy the
sensor now and remove the sensor with a wrench and then work on the connector. I agree you want to be
careful and not break it. It is probably full of corrosion and needs back and forth action to get it loose.
#13
Dude if you are ever stuck in any kind of traffic you will want that fan to come on. You could wire a temporary switch (on/off) just in case. Your car will overheat faster than you think. If the ambient temp doesnt get above 30 you might be ok, but i doubt that will happen unless you live in Nunavut. My 2c
#14
I've been defeated by microscopic things only to come back and win in the end. I sure hope I can handle this.
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
I probably will just end up ordering the switch, but it's always nice to test a theory.
#15
So since this sucker, the fan switch that is, happens to be on the radiator, am I going to have to drain the coolant to replace the switch?
#16
the hole. You would like time to investigate if any gelled crud is built up in the lower radiator isolating the
coolant from the sensor, so placing a hose on the drain nipple on the right side of the radiator would allow you
to collect clean coolant for re-use, You want to use a sealing washer on the switch, so you need the old one if
you didn't buy a new one.
#17
New switches appear to come with a new sealing washer thankfully. I would hate to re-use the old one. I probably wont be sticking my finger in anything. I'll plan on capturing the coolant and hopefully reusing it.
Thanks!
Thanks!
Jack in FL
09-28-2006 01:44 PM
audi/s/scott
Audi 100 / A6 (C4 Platform)
02-25-2005 05:58 AM
Luxus Panzer
9
04-25-2004 10:38 AM
