smog braintrust: what would cause high hydrocarbons at idle?
#12
<A HREF="https://forums.audiworld.com/s4s6/msgs/105543.phtml">is the post</A>. I didn't even change the oil. I knew it was plugs - also I brought the car in on a very cold day when the motor was still pretty cold.
#20
has ever since I chipped it.
here's what I've done in the past to get it to pass: New plugs, and o2 sensor, also run it almost out of gas, then put a few galloms of lower octane fuel (87 or 88). Stay outta the boost and go get your IM test. make sure the motor is nice and warm. or if you are in the situation, during the test procedure, whenever the test drops to idle, hold the test probe about 1/2 in the path of the exhaust. ( so it gets a little fresh air). HTH
cloudcitycollective
30v V6 Discussion
01-17-2009 09:39 AM
gmanea
07-11-2001 08:04 PM
