So, I finally have money for a big brake kit...
#12
993tt Calipers:
993-351-425-10 Porsche 993TT Front "Big Red" Caliper LEFT
993-351-426-10 Porsche 993TT Front "Big Red" Caliper RIGHT
BRACKETS
8A0 615 125 A
ROTORS
4D0 615 301 A
Also:
Bolts, long (caliper to bracket)
999.067.041.09
Bolt, short(Strut to bracket)
N 100 880 03
Bolt size is: M12x1.25x25mm
Or cut the existing, what I did.
Some folks have just cut down the existing bolts
Wear Sensors
993.612.368.00
Wear Sensor holders
928.612.361.00
PADS, if you choose Mintex Red
MDB1860AF
BRACKETS
8A0 615 125 A
ROTORS
4D0 615 301 A
Also:
999.067.041.09
N 100 880 03
Wear Sensors
993.612.368.00
Wear Sensor holders
928.612.361.00
MDB1860AF
#14
Unfortunately, they are no longer in business. Kit was $1400, ss lines, fluid Brembo rotors 314X30 and 996 calipers. They squeal when they feel like it.
#15
I bought a used 2B Big Red set-up & had to source the Bolt, short (Strut to bracket) & the size for the 2B kit is a Socket (allen) M12x1.50, 45mm (Not the 1.25pitch as mentioned). The stock bolts won't fit in their bracket, which means you can't cut off the ends to fit. It has to be a german bolt because it's "fine thread" not made in the USA & faces the expensive Euro-exchange rate putting them at $6.10 ea. for the 4 bolts. They come in boxes of 10 & places want you to buy the whole box. What a pain in the *** to find locally in Seattle, but I found 4 in Kent after a couple of days of calling around & going to different auto shops.
SCarGo02
Audi Original "S" Cars
91
12-14-2007 09:11 AM
Sloooo4esT
11
05-06-2004 10:17 AM
