Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
So I put the MTM wastegate spring in last night...
Old 11-29-2005, 04:55 AM
Member
Just-Emre's Avatar
Default So I put the MTM wastegate spring in last night...
...and the car makes boost frighteningly fast. Could the spring be too stiff? I haven't had any WOT runs with it yet, 1/2 throttle makes it jump to 25psi even at 3.5kish RPM, which seems to be too quick.
Any thoughts? Could this spring have been meant for ta K24?
Old 11-29-2005, 05:03 AM
Member
EvanUrS4's Avatar
Are you complaining about fast spool? It's not overboosting right?
Old 11-29-2005, 05:09 AM
Member
Just-Emre's Avatar
I haven't let it get to the point that it's over boosting, but I almost think it might.
Old 11-29-2005, 05:49 AM
S4-Fireblade's Avatar
Default Nice to hear that added some more hp's to your engine only spending a few bucks!
Start testing with the WG screw completelly unscrewed untill you find the max sustainned boost for you RS2 setup(1.8/1.9bar = 26.5/28psi). In my case, no turns are required on the original screw.
I spent two months trying to figger out what was going wrong...
Old 11-29-2005, 06:48 AM
JAA 4.2's Avatar
Default If your ECU is controlling boost, it should still control to the correct boost
The stiffer spring just raises the minimum amount of boost your car can control to. However, if you have a manual boost controller, you'll need to dial it back, or you will get however much more boost the difference in bar the two springs were rated at.
Old 11-29-2005, 07:01 AM
Member
Just-Emre's Avatar
No MBC, so I should be good? ECU still controls the boost.
Old 11-29-2005, 07:27 AM
Stroker//S4's Avatar
Default Emre, out of curiosity, what are you running for software?
I think I remember you saying you are full RS2 with like MAF, fuel pressure regulator and injectors, correct?
Old 11-29-2005, 07:37 AM
germantoy's Avatar
Words from a audi god "stiff wg springs will make you realize how good your clutch is"
Old 11-29-2005, 07:38 AM
90sportin's Avatar
Where can you get a MTM spring?
Old 11-29-2005, 08:25 AM
pearlurs4's Avatar
I have seen them from time to time on Ebay
Quick Reply: So I put the MTM wastegate spring in last night...
