steering damper replacement
I saw few posts that claimed that you need to remove/lower bolt that holds steering damper to rack due to clearance issue.
I was able to do it without it:
- rotate steering wheel all the way to the left, so you can get better access to the nut and remove the nut at the rack bracket;
- rotate steering wheel all the way to right;
- remove the bolt that hold the dumper to the body;
- Now, notice a slight curve on the body right above the bolt at the rack, it will let you wigle old dumper out and put new one in;
I also added thread lock to bolt at the body and nut at the rack.
Took about 10-15min.
<a href="http://www.worldimpex.com/parts/genuine-part-damper_552412.html">World Impex VW 305 425 021 2 $27.50</a>
<a href="http://www.partsgeek.com/catalog/1990/volkswagen/fox/steering/steering_damper.html">PartsGeek.com VW 305 425 021 2 $27.99</a>
I asked AutohausAZ recently and they had no idea if they would ever get this part in stock again.
blink
05-25-2015 08:10 AM
UrSobsessed
Audi Original "S" Cars
01-11-2009 02:02 PM
