Suspension rebuild/Bilstein revalving
Ok some newbee question here, bare with me.
I'm about to tear apart my crapped out original 95 S6 suspension and rebuild with H&R sports, Bilstein sports, ECS camber plates & all new bushings & hardware bits. Motor & transmission mounts already done. I have read about the preferred Bilstein revalving to 10% stiffer compression and 30% stiffer rebound. My question is at an additional cost of $300 for revalving, is it worth it? My S6 is used as a short distance daily driver on good roads with the occasional weekend canyon carving getaway.
Can anyone suggest a good place to source the Bilsteins? So far I found them the cheapest at ECS for $475. From what I have read about revalving it seems like they rebuild the strut to the point that it may be worth it to source a used set of Bilstiens in good condition and just have them revalved. Anyone BTDT? Warranty issues? Anyone have a set they want to get rid of? Turnaround time for the revalving?
Also, is the HRSB upgrade fairly easy to do as a add on at a later point or is it best to do while the rear susp is apart? Hap you still making these?
I have found alot of info on rebuilding the front suspension but not much on the rear. Does anyone have some helpful comments or at least can you point me in the right direction?
I do have the parts list for the entire suspension rebuild (+ ETKA & Bentley) however some of the parts seem like they could be reused barring the ones that are required to be replaced that is.
Tirerack.com has good prices on springs and shocks, fast and reliable shipping too.
With H&R Race springs, I got plenty of oversteer, especially in wet. If you go H&R Sport then maybe a rear sway bar will help. I wouldn't bother unless you are going to take your car to the track more than 3 times a year.
It just takes about forever to get one fabbed. Your car will NOT be an oversteer monster despite what Xel says. There are 3 adjustments good for 125, 140 and 155 lbs of anti-roll. There are guys running at all 3 levels. It just depends on your other suspension mods. Before I went to coil-overs, I loved the +10/+30% on the Bilsteins. It was a great street setup that could perform on the track.
Hap, wit dakine suspension thoughts not from Evahboost, Maguire
probably exaggerating a bit, but it rains a lot here so getting the rear end out is easy even on stock software, hehe
M3KILR
09-26-2005 12:17 PM
mark101
10-14-2003 07:43 PM
unknownvirus
09-06-2003 05:34 PM
byron - b'rizzle
04-08-2003 06:05 AM
