transmisson CRACKED !!!
#12
I think if you get the clutch right, you do not need the spacer for either the RS2 or B5S4 trans as it is attached to an AAN block in a C4 UrS4 or UrS6. The key is getting the correct pressure plate that is compatible with the UrS4/6 dual mass flywheel.
#13
When I changed mine out, I kept it original but exchanged for less mileage flywheel, clutch and pressure plate. If IIRC there was definitely an Aha moment with the installation, patience is the key.
#14
You should have used the C4 S4/S6 flywheel, clutch and pressure plate. A good welder with the proper equipment could fix your bellhousing.
ok so i was putting on the b5 6 speed today, and it wouldnt go all the way on as if something was blocking it, my idea is because i also put on the b5 s4 clutch flywheel and pressure plate, which is a little bigger overall than our stock ones, and i think thats the reason for it not slipping on? is this possible that the problem could be the b5 parts and i have to use the stock flywheel pressure plate and clutch?
....so then while putting all this on, i had the whole transmission about half an inch from going on and i think the problem is as i stated above, but i started tightening the bolts, and as i was doing the left side, i was tightening the bolt and the bell housing cracked? now im clueless what to do, can this be welded back together? any ideas for this happening?
#18
Agree. What I am saying (as is Skollie above), one combination that works is the OE UrS4 Dual mass flywheel, clutch and pressure plate. Use this combo = no need for the spacer. Since I am not a fan of single mass flywheels on this car, I do not offer another combo.
