Turn signals don't work... Hazard button doesn't work. Any guesses? BTDT's?
#11
<a href="http://www.ziomal.itl.pl/motoryzacja/download/audi/Audi_A6_96_schematy.pdf">Click.</a>
Scroll down to "Exterior Lamps Circuit, W/O DRL".
It shows the Emergency Flasher feeding both the Emergency Flasher Switch and the Turn Signal Switch. There's a relay behind the instrument cluster that might be the Emergency Flasher.
#12
AudiWorld Expert
relay (as what you pointed out it should be up behind the instrument cluster). So I did find it and I found the wiring connector that I'd forgotten to plug back in. Signals work now, thanks a lot!
The J2 relay is attached to the backside of the dash and is kiddie-corner up to the right (passenger side) of the ignition switch
Obscura
13
04-15-2010 04:16 PM
A4PlayQuattro
10-05-2006 06:09 PM
