under boost till close to 5000 rpm, I hear a hissing coming from drivers side
sounds like somewhere under or behind the dash. at around 5000 it stops hissing
could I have a boost leak? I did a half *** pressure test no idea how mnay psi but it seemed to hold. if this is a leak where should I be looking. I guess I'll check MM hose fisrt to see if its slipping, but this kinda sounds higher up than that.
thanks oh samco kit is installed
even hear it under very light throttle when turbo comes on
Re: under boost till close to 5000 rpm, I hear a hissing coming from drivers side
Your car is about xplode sell it to me for $1000.. :-)
Check the MM hose and even the intake, my samcos are moving off that all the time.
Good luck,
Shawn
Good luck,
Shawn
