Want a chip for my UR S6 Avant but do not want to make turbo lag (Low end) worse?
#12
Thanks!! Which commpany is NED with? I see Alex on above link. Was Ned the Hoppen one? Should I consider the one from Alex over Shadetree who is local for me (Denver)?
#13
Talk to both Steve Eiche at Shadetree and Alex before you make your decision.
#14
So would you say that Alex's intended acceleration might help me out more than Shadetree? Whos will help me out most with turbo lag or are they very much both going to be fine?
#15
I can only speak about Alex at this point, Ned was the original tuner on my car and it was good at Stage 3, Alex has since done some work and we're going to be updating a bit more now that we're at S3+ by adding a Wagner EM and a ball bearing turbo similar to the RS2 comp unit and a new, larger downpipe. I hear that there is no need to go after the intake side other than a FMIC.
That'll all require additional updates to the software and of course we'll be going to new injectors.
I've already done the fuel pump as we were at the limit of the stock unit.
All I can say about Alex is that he's always been fair, has usually had all the bits on hand and is honest to a fault when it comes to working on the car and his rates are very good.
Having owned Porsche's and tracked them over the years I'm familiar with process and I'm quite happy working with Alex and see no reason to go anywhere else.
19885ktqcd in Wa. st
03-10-2004 01:43 PM
5280 Quattro Avant
09-23-2002 02:50 PM
98Turbo
09-26-2001 12:11 AM
Mike
11-11-1999 05:34 AM
