what is the fricking secret to the lower front ball joint removal?????
#24
Typically only spread as much as allows the balljoint bolt to pop upwards, which tells you that you've released the tension.
The above horror story was most likely due to a number of factors:
#1 Cinch was spread too far,
#2 the factory bolt was obviously not replaced w/ the correct bolt,
#3 They most likely used air impact to "torque it properly",
#4 They were not paying attention to their work.
The correct bolt, when installed properly will NOT allow the ball joint snub to come out due to the locking groove in the ball joint snub. No way it's coming out Period.
I'll bet they used a bolt w/ threads all way up to the head of the bolt. The factory bolt and any replacement must be a 10.8 grade bolt AND have a non-threaded shank. (Of course threads on the end but none in the middle).
#25
I must have spent a hour fiddling with the lower ball joint on a 4KQ over the last few days. Just wouldn't come out. Try turning the tire left/right a bit. Mine popped out with the hub turned all the way inward with NO leverage. Also try putting a jack underneath the hub and leveraging upward (with a block of wood).
Brdman*
16
10-18-2006 01:50 PM
beejohn
06-05-2005 10:13 AM
es4uerzo
10
02-19-2005 01:26 PM
es4uerzo
14
02-19-2005 08:09 AM
Zzak
02-14-2004 02:01 PM
