What are my options for front bumpers for our cars? Will a b5 S4 bumper fit?
#11
<center><img src="http://matthew.pelkey.googlepages.com/IMG_2635.JPG/IMG_2635-large;effect:autolevels,100.jpg"></center><p>While traveling to Jackson, WY I hit a jack rabbit at high speed and it destroyed the lower valance. I had just replaced all three of the lower grills before I left. Now there is no where to attach them. Any ideas on how this can be repaired? I like the LLTEK lower valance but am not sure if it attaches to pieces that are now missing? Also, does the LLTEK piece work with the Apikol FMIC?
#12
The entire bottom section (exception being a couple inches on the sides) needs to be cut off anyways. You should be able to sell your lower grill pieces to make up for some of the LLTEK's expense.
#13
<center><img src="http://www.anyboard.net/gov/mil/anyboard/uploads/Atlantic_bloomington_oldschool_representin.jpg"></center><p>But maybe if you wanted to do alot of custom work to make it fit, it could be done. The C4 isn't much wider than the B5. I mean the strut towers on the C4 are the same distance apart as on the B4. The C4 is just longer.
#14
of the bumper so what you lost is of no consequence. However, you will defintitely have to trim the back of the LLTek at least somewhat to fit an Apikol FMIC. No biggy. Just a lot of trial and fitting, taking the LLTek valence equipped bumper on and off. Best done with a patient friend and a Dremel with a spiral saw blade.
#16
That sounds like the way to go. I was on the fence about getting the LLTEK earlier when the grills needed replacing. I don't know that it would have held up much better based on the amount of damage that was done.
Does the belly pan just slide into the LLTEK piece too?
dzzeiks
13
01-08-2009 03:44 AM
Jason Sowers(rs6's)
Chicago Discussion
05-01-2008 05:06 PM
gbaker
Canadian Discussion
09-25-2006 06:45 AM
SCd_Walter
Southeast Discussion
05-08-2005 06:44 PM
AirVtec
01-28-2005 09:25 AM
