Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
What's 443907388 for?
Old 09-15-2008, 11:19 AM
Lane Shark
- GT Style -'s Avatar
Default What's 443907388 for?
ETKA calls it "switch for longitudinal acceleration".
Old 09-15-2008, 11:45 AM
yodasfro's Avatar
ABS inertia switch
Old 09-15-2008, 01:10 PM
js0ne's Avatar
SRS inertia switch (edit: wrong answer)
Old 09-15-2008, 01:23 PM
Lane Shark
So is it for Airbag or ABS? What is it's fuction & what happens if not connected?
Old 09-15-2008, 01:39 PM
js0ne's Avatar
Default ETKA shows it under the ABS section, it was used in the S4 and not the S6.
it'll probably create an ABS fault and the ABS might not function.
Old 09-15-2008, 01:47 PM
js0ne's Avatar
ELSA makes no mention of the above sensor.
Old 09-15-2008, 04:38 PM
UrS4boy's Avatar
That PN shows on 927-00. If you go to 972-79, it is connected to the ABS harness.
Old 09-15-2008, 05:37 PM
UrS4boy's Avatar
Default Longitudinal Acceleration Switch info from S2Central.net
Under the ABS section:
"ABS - System Description : MY91-93
Longitudinal Accelerometer - It is unclear if all early ABS systems on the S2 have this component. More research is needed as I suspect it may have been deleted before the introduction of the OBD equipped ABS controller became standard equipment. The purpose of the accelerometer switch is to close an electrical contact in the event of sudden G-force increase in a forward direction - such as when braking heavily. Notated as F113 on the schematic.
ABS - System Description : MY94-95 Revisions
At some point in time, Audi decided that the risk of someone blaming them for causing an accident by allowing the driver to disable a safety feature such as ABS was too much of a risk to continue with. For the 1994 model year, a number of revisions were made to the ABS on the 80/90 series. The most significant change was the deletion of the ABS cancel switch. In relation to this change, there was no need for the combination relay. Finally the longitudional accelerometer switch was also deleted. "<ul><li><a href="http://www.s2central.net/main_frame.html">Click here and then on the ABS link.</a></li></ul>
Old 09-15-2008, 09:10 PM
Lane Shark
thanks
UR-maninblack
12
12-23-2006 12:15 PM
S4 Slowpoke
10-10-2006 06:10 PM
Dr. Jitter
VAG-COM Discussion
06-23-2005 02:10 PM
h8r
05-24-2005 09:21 AM
technics100
06-14-2004 01:02 AM
Quick Reply: What's 443907388 for?
