whats a true rs2 setup?
-rs2 turbo $1615cnd
-rs2 exhaust manifold $786cnd <(wagner tuning)(034motorsport $$$???)
-rs2 injectors (37# lbs/hr delphi D3165BA $205cnd for all 5) racetronix.com
-ecu chip $500-$900us range
OPTIONAL
-rs2 maf $497cnd or "de screened oem maf" or 928? or 944 turbo?
-rs2 cam $1083cnd "optional"
edit>>no need to change coolant/oil lines when used in AAN S4.
ps I will post where and cheapest prices I have found..if you know of somewhere better lmk I will edit it
OPTIONAL
does the RS2 cam (not much benefit). I think you can find RS2 turbos for less money than that. If you go with RS2 clone injectors or Lucas/Delphi injectors, you can bring down your costs considerably. You don't need the RS2 MAF, tuners have software that uses the stock MAF. Software is anywhere from $500 to $900 (US).
YG Hotmail as well.
YG Hotmail as well.
Of course, I wouldn't run the 7A ex. cam alone with all the supposed overlap, but I *would* run the RS2 alone. I think Rich has done the testing via his buddy in Seattle. I know they were missing one cam set, but I can't for the life of me remember which one among stock, 7A, and RS2.
As other have said, most don't use the cam.
Personally, I'd use the true RS2 injectors. The MAF is debatable.
What are the differences? Diameter, screens, etc...
Is the RS2 MAF the same part # as the 968 MAF or does Porsche have a different part #?
