Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Where to get 300kPa MAP boost sensor?
Old 08-08-2003, 01:42 PM
  #11
New Member
urS4isS2pid's Avatar
Default knock knock knock :)
maybe just more fuel and less advance. take the fuse out just for a minute and there's no failsafe mode, just the factory defaults. what's so hard tuning motronic? mail me and i can give you some ideas.
Old 08-08-2003, 02:22 PM
  #12
Junior Member
Mihnea's Avatar
Default Re: knock knock knock :)
You didn't understand nothing regarding how those ECUs work and the way the fuel supply is taken care of, I'm sure of that right now! Way to go man!
Less advance? yeah right, until the turbine melts? In case you didn't know, advance has to be increased in order to avoid the mixture self burning before the spark arrives and in order to keep EGTs low, but I can see indeed that you lack some serious turbo motors tuning experience, even I wouldn't have thought of that a few months ago until I got to tune a few 350+ HP cars! You're hopeless, that K27 will drown the engine in fuel or will burn the heck out of the injectors trying to run them at 200% duty cycle!
Old 08-08-2003, 02:39 PM
  #13
New Member
Default whow whow! take it easy man!
advance till it pings, retard. keep A/F at 14.7. what can go wrong?
Old 08-08-2003, 02:47 PM
  #14
Junior Member
Mihnea's Avatar
Default You'll melt pistons with an AFR of 14.7:1
and how will you advance till it pings then retard if I may beg your pardon???
Old 10-03-2003, 10:44 AM
  #15
New Member
zVMAP's Avatar
Default Re: Don't like being negative
Indeed it is not recommended to set a VMAP-D-4 @ 3.8 bar without the proper chips. However if set properly it is not an issue ... the end user would have to open up the ECU and change the settings ... I would be more concerned about a 10 year old Bosch sensor failing ... this would lead to some very spectacular effects. The VMAP-D-3 has a maximum of 300 KPA ... but can be upgraded to a VMAP-D-4 with new firmware.
Best regards,
Feico van der Laan
Old 01-28-2004, 01:49 PM
  #16
5kcstq's Avatar
Default Map sensor failure mode?
What is the failure mode of a Bosch 300kPa sensor? Does it do something specific, or can it vary?
BryanG
11-11-2007 06:41 AM
petervan
10
10-05-2005 05:11 PM
CARSNPLANES
04-28-2005 08:53 PM
Vtec_Killer
02-01-2002 01:43 PM
Hawaiiannights
05-27-2001 12:56 PM
Quick Reply: Where to get 300kPa MAP boost sensor?
