Windhield washer fluid tank removal?
Here's the deal, I have a windshield wash fluid leak everytime I use the pump, it seems like it squirts fluid somewhere underneath the tank itself/pump area. Took the driver's side headlight out and still couldn't get to it, and by that time it was getting dark outside so I had to put everything back together.
The headlight squirters dont work anymore, so me thinks that the headlight washing hose must have came off the pump neck or broke or something like that.
I really need to get the reservoir out, but the p/s fluid reservoir is in the way...
Help? Pleazze!
Help? Pleazze!
It slides up it's bracket. Then remove that bracket.
Remove the IC to TB pipe, that opens up alot of space.
The tank is L shaped, and there are a couple of bolts that are a PITA to get to at the bottom.
For all those connections, I basically re-did all of them with new clamps. I also bought a new pump, and siliconed that into the tank.
Also, STFA, there is a thread with picts.
Shep 1.8T
12-19-2006 06:02 AM
RNO.Audi
03-07-2004 05:13 PM
S4Patrick
12-15-2000 09:53 AM
