which wire on coil pack used for tach? need help with remote starter install
i have it all wired up.. search says black wire in wiring loom for coil?
the car cranks but will not stay on i need signal to tell alarm the car is on
<center><img src="http://pictureposter.audiworld.com/15624/enginespeedignitiontimingsensors.jpg"></center><p>
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/116211.phtml">Link to ECU pin-out - looks like Pin 40</a></li></ul>
perfect thanks.... looks like G28 pin 40 should work i wonder if its easier to tap into the g28? if not ecu i will go with
i followed the senor to the coil pack loom... its a 3 wire conector i tried the black wire nothing..i tried the brown and it works but then the car will shut off..not sure what it can be
banana s4
10-24-2008 10:49 PM
spiralsmurf
Audi Original "S" Cars
12-10-2005 01:48 PM
