Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
WTB: ECU
Old 02-03-2006, 04:50 PM
  #11
bluevr6's Avatar
Default How would I diagnose this?
In last two weeks:
Swapped in known good PSO's amd coils. Installed new cam position sensor.
Installed new (borrowed) MAF
None of this fixed the issue, though the MAF did reduce the severity.
Checked for boost leaks, found none.
Help......
Old 02-03-2006, 05:14 PM
  #12
kday's Avatar
Default Hmm.. Unplug your WGFV with your suspect ECU in the car.
That will at least tell you whether the suspect ECU can run your engine smoothly at low boost.
Old 02-03-2006, 05:18 PM
  #13
bluevr6's Avatar
Default Uhmmm, actually, after checking everything out, the only miss left is at WOT above 3500 rpm oin 5th.
All other engine speeds and throttle postions smooth.
Willl check tomorrow.
Old 02-03-2006, 05:28 PM
  #14
kday's Avatar
Default Well, crazier things have happened, but it seems odd that...
... your ECU would only act up under those conditions. Have you completely ruled out a boost leak?
Old 02-03-2006, 07:04 PM
  #15
Member
ChrisUrS6's Avatar
Default No, they still deal with Conestoga wagons....
Joke...... they are a reputable chip tuner for our cars and more than a few on this list are running his software. He's a good resource. Use him.
Old 02-04-2006, 04:39 AM
  #16
bluevr6's Avatar
Strange, shadetree.com brings up a snowmobile shop. Contact info.
Old 02-04-2006, 04:58 AM
  #17
Member
Only-Emre's Avatar
shadetreesoftware.com
Old 02-04-2006, 07:02 AM
  #18
bluevr6's Avatar
Thanks
Old 02-04-2006, 07:20 AM
  #19
New Member
zoofs4's Avatar
Default Re: WTB: ECU
I had a similar issue and I checked my coils using one of those cheap $8 spark gap testers. You can visually see which coil is weak due to the fact that they don't clip right in to our connectors. The coil must cause a spark to jump over 2 gaps. A weak coil will have no spark or an orange colour spark. A strong coil will still jump both gaps with a white colour spark. Try this before replacing ecu.
94LSC
16
05-26-2021 10:49 PM
toeneal
10
10-02-2008 05:21 PM
haz2avants
13
10-20-2005 03:49 AM
s4power
08-14-2004 07:57 AM
Quick Reply: WTB: ECU
