034 motor/tranny mounts or not? Subframe bushing ???'s too.
I am going to replace subframe and motor/tranny mounts, control arm bushings, etc. As the 034 mounts are 10 times the price of the regular ones are they really worth it? Are the 4 front subframe bushings fairly straightforward? The rear bushings on the front subframe seem to be an issue for some people. What do you do if the rear (back of car) subframe bushings are bad as they are NLA?
had decent horsepower on his car. Just pulled the motor this weekend and the mounts were in fine condition.
Former Vendor
The density line, or the motorsport?
The density line is what 90% of folks want/need. It's a much added improvement in the firmness and feel of the driveline, without the vibrations that come with the territory of the motorsport mounts. The density mounts will drastically reduce the movement of the motor and trans during sharp throttle/clutch transisitons, making inputs much crisper and keep everything locked down where it should be.
Also... 10x the price?! Where are you buying $6 motor mounts and $2.50 tranny mounts??
all you really need is a good snub mount and window
weld sealer filled tranny mounts
window weld = 10 bucks
Density is probably the best choice for tranny mounts. But I didn't see anything for motor mounts except for the ones that say they are not for cushy cars. Is there one that is firmer than stock but not jarring? My car is harsh enough.
UrSoccer_mobileĀ®
Audi Original "S" Cars
12
11-16-2007 12:17 PM
nate @ 034MOTORSPORT
07-23-2007 08:14 AM
Ex-PzKW Cdr
Audi allroad
06-28-2007 12:45 PM
