Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
245-40-18 tire pressure recomendation? please explain why run different pressure
Old 10-23-2008, 06:56 PM
Sloooo4esT's Avatar
Default 245-40-18 tire pressure recomendation? please explain why run different pressure
in front tires than rears
thanks, never really understood tire pressure adjustments
Old 10-23-2008, 08:55 PM
UrS4boy's Avatar
Default In my yute, I did AutoXing with a Jetta 1 built to GLi stds. In order to keep the front tires from
rolling under, (205/60/13 btw), I needed to put about 44 psi in them. The rears needed some help to prevent side wall roll, but not as much, so their pressure was set at 36 psi. By playing withthe tire pressure, e.g. less in the rear, I could induce a bit of oversteer (helped on some courses).
On the UrS, I just run 32 psi all round. (Normal driving)
Old 10-23-2008, 09:20 PM
Sloooo4esT's Avatar
I currently have 30 in front and 32 in rear. lil less air = more tread to road contact?
Old 10-23-2008, 10:00 PM
UrS4boy's Avatar
Less air = tire is harder to push and the outside corners wear faster.
Old 10-24-2008, 03:12 AM
TXurS6's Avatar
Default The front tires support more weight
For the tires to keep an optimal footprint on the road the fronts would need more pressure to support the additional weight. Adding pressure to the fronts car will reduce understeer (to a point).<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Ftires%2Ftiretech%2Ftechpage.jsp %3Ftechid%3D58">http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=58</a></li></ul>
Old 10-24-2008, 03:55 AM
quattro5.v.2's Avatar
Old 10-24-2008, 03:58 AM
Default in my 200tqa and C5 I used to always run +4-6 over recommendation in the front
and rear close to stock (less understeer).
haven't played w/ S6 tire pressures yet...
Old 10-24-2008, 06:03 AM
s4surf's Avatar
stock car, 38F 35R helps with tramlining and countering the chunk of weight up front
Old 10-25-2008, 03:23 PM
AUDIS6DOIT's Avatar
Default Im running 39 up front 37 in the rear,learnt my lesson the hard way worn shoulders due to under
inflation,always check my tracking religiously every year.
Maini
Wheels & Tires Discussion
04-08-2008 08:40 AM
Jeffc31337
TT (Mk2) Discussion
11-04-2007 02:26 PM
entryleveluxurysedan
11
04-05-2007 07:01 AM
ScottyZ
05-19-2001 06:51 PM
Quick Reply: 245-40-18 tire pressure recomendation? please explain why run different pressure
