5 cyl diesel cylinder head same as the urs4 cylinder head?
ok long story just found out my head is cracked on my motor in three spots, and is leaking, uggg what a mess, but i need a new head asap, would like to know if the head of the eurovan is the same or, would it work as a direct swap for the urs4, thanks so much guys
Best option is probably a 7a, I am in the process of rebuilding one
If you get the 7a you have to get some machining done for the water manifold/cam sensor but It will likely be cheaper/easier to find then AAN. Try force5, or shokan
If I hadn't already started on mine I would offer it.
good luck
good luck
