Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
95S6 Avant undercarriage clank thinking it is driveshaft. Also tranny seems a bit clunkier- cont.
Old 10-22-2005, 04:58 AM
snowchaser's Avatar
Default 95S6 Avant undercarriage clank thinking it is driveshaft. Also tranny seems a bit clunkier- cont.
My mint UR S6 only has 110K on it and ever since I had the rear main oil seal leak fixed (new clutch at same time) the car seems to have had a minor clank only over bumps. Now it clanks on sharp slow turns and when starting out from a stop. the tranny seems slightly less smooth as well. Do you think they might have put it out of allignment when the dealer did the clutch and rear main? That was 1 year ago but that is when I started hearing the noise. Is the driveshaft clank a common problem on these cars? It was on my 91CQ.
Old 10-22-2005, 05:19 AM
Tech Guru
4Driver4's Avatar
Where exactly does the noise come from?
Old 10-22-2005, 08:37 AM
snowchaser's Avatar
It comes from under rear passenger seat almost center of car? Most not. when turning sharp slowly
Old 10-22-2005, 09:34 AM
parkpy's Avatar
Default You had your clutch done...so
1)Get your car on jacks, and check all your exhaust hangers. There is one right after the the cats that often comes loose in mine. There is a clunk at deceleration, and when I go over bumps.
2)You might have bad tranny mounts, but the only way to tell would be to take them off. That'd take you about 2hrs, at most. Not too difficult, not the easiest thing if you don't have space to check it out
3)Driveshaft: Your mechanic might nt have properly attended to the driveshaft. But, your car might also have a bad Center Driveshaft Bearing Support. How do you tell? See what it does while accelerating and ubruptly coming off the gas.
I've experienced all of these, and have had the loose exhaust thing return after going over some rocks when offroading. I know the activity you do in your car, so I am thinking it's an exhaust thing.
If it's not, the other two are way more expensive to fix. Like actually replacing hundreds of dollars worth of parts, whereas the exhaust problems just needs to be retightened.
Old 10-22-2005, 09:40 AM
spiralsmurf's Avatar
could be the center bearing but it wouldn't clank unless ALL the rubber was gone
Old 10-22-2005, 09:21 PM
snowchaser's Avatar
Default Paul: I think it is the center diff since when I hit the gas hard to clunk the tranny it is noisy a
and when I decelerate it clanks. How are you? I lost your # so e mail me at sconney@comcast.net with it.
ajg617
10-22-2013 08:40 AM
acm377
03-04-2008 12:58 PM
A6turbo530
12-21-2007 02:15 PM
michael66899
09-27-2006 02:22 AM
ImAWinner
11-05-2005 12:37 PM
Quick Reply: 95S6 Avant undercarriage clank thinking it is driveshaft. Also tranny seems a bit clunkier- cont.
