ABS light on...............
hey man seem to be i got a tons of problem now.need a lot of help from you guys at this time.
my car has some problem with ABS.Today after i got my car back from mechanic.I feel something wrong about my brake.Seem to be the ABS is too sensitive.when i hit the brake.it seem there's some vibration from the brake pedal(look like the abs is working) even gently braking and then the ABS will light on.and then that symthom will be disappeared.I'm pretty sure that it's from ABS system.I tried to remove the
ABS sensor at the front wheel and clean up. and
pull it out a bit from the old position.my mechanic recommended me to do that.but the problem is still here.anyway,he told me to try to adjust the ABS sensor again.the cause should be there... any ideas?
Big thanks
POP K.
Big thanks
POP K.
everytimes when i change the lane hardly or sharp curve the ABS will always light on.i would say it's weired.look like some wires were loosen. anyway,i will check with the VAG when the ABS is light on tomorrow.
My guess is that your front wheel bearings are worned out(or you left the transmissions end bolt loosen) and that the sensor is beeing pushed out when curve hard!
OrangeMan
05-23-2011 06:31 AM
Omega Supreme
05-18-2008 02:59 AM
thewatcher101
07-16-2007 08:59 AM
ABS woes... first brake pedal push when driving car - feels hard, engages ABS sometimes... light on/
aerohr
06-04-2006 05:06 AM
