After run fan doesn't shut off.
Under the intake on the coolant pipe, the small switch with 2 seperate wires(no connector). Unplug the wires, if the fan stops then you have a stuck thermal switch, if it keeps running, then its probably a stuck relay. Unless you have some weird wiring problem I've never seen. This is only in after run mode? Or does the fan always run even with car running/ac off. Because there are a few relays that control the fan.
cbohem
01-31-2006 01:41 AM
david9999
09-29-2004 12:49 PM
