after-run pump question
Hey, I know there are lots of posts on the MFTS and after run pump relay bla bla bla.... but here is the thing... I tested the afterun pump today by pulling the two connectors off the temp sender and bridging them. The pump came on. YAY!! but the fan did not.. just so we're clear.. this is the little electric fan on the pass. side. Is this fan supposed to come when performing this test? like I said, the pump came on and the fan did not. What now?
TIA
TIA
Under the hood, just under the windshield on the far left, there is a fuse/relay box. Pull out the 214 relay in the front of that box and jumper the front and rear pins and the fan will come on.
so let me get this str8... ONLY the afterun pump comes on when the temp switch reaches threshold. The fan is connect to yet another sensor and will only come on if radiator temp is high?
Will try the jumper idea thanx alot guys.
http://www.sjmautotechnik.com/troubl...oling.html#fan
I have problem like this before.
and use this check procedure and found Relay No 324 mulfunction.
I sent to elec repare 14 US
How can I test the fan only to see if it works? from what I read on sjmautotecknik.com the fan should also come on when AC is on or the engine is hot. Mine NEVER came on during the summer.
TIA
naaa that never worked either
I figured as much... but that doesn't work either. When I turn on the AC, fan still does not come on. I think the fan motor is finished or the fuse is blown. I will have to check all the relays and fuses.. Does anyone have the wiring diagram for this fan?
Link to an A6 wiring pdf that should have the answer you are looking for re: fan wiring.
http://www.ziomal.itl.pl/motoryzacja...6_schematy.pdf
