Air Leak crankcase breather check valve
<center><img src="http://pictureposter.audiworld.com/100685/dsc02521.jpg"></center><p>I sometimes hear a small air leak when under boost. I think it is coming from here. Has anyone had this problem or know what parts to get and how to replace this stuff? The clamps are crimp-ons. And it's not easy to get in there.
In the bently diagram (link) this is items 4, 5, 6 and 7.
4 - Evaporative Emission (EVAP) canister purge regulator valve -N80-
5 - To connection on intake manifold, lower Throttle Body (TB) flange
6 - Check-valve
7 - To crankcase housing breather<ul><li><a href="http://pictureposter.audiworld.com/100685/fuelinjection-components.jpg">http://pictureposter.audiworld.com/100685/fuelinjection-components.jpg</a</li></ul>
6 - Check-valve
The "leak", if it exists will probably come from other place than that.<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/29825.phtml">https://forums.audiworld.com/s4s6/msgs/29825.phtml</a</li></ul>
As well as some pics in my poster.
2 tips & you should be on your way -
Remove the boost hose from the TB.
Use a dremmel tool to cut the old clamps off. Use new Ideal clamps to assemble.
See my pic poster for how to test the old valve out of the vehicle.
Island Boy::Jeproks
04-03-2007 06:24 AM
Russ Scott
11
08-07-2006 11:06 AM
redwagon
08-22-2005 05:46 PM
Ghostfire
03-10-2004 05:48 AM
