Air-Water intercooler? Anone have one?
I run an a/w intercooler in the Miata. It's great around town and for short bursts...kinda like the stock urS IC. However on the track, where I really need it, it heat soaks.
As I say, the only possible advantage over the stock system is that it _may_ be less susceptible to heat soak when you are sitting in traffic. The stock IC gets no airflow unless the car is moving while the A/W IC at least might get some cool water ...depending on where you install the heat exchanger. Of course, you could achieve the same result by installing an FMIC in front of the AC condenser where the radiator fan will draw cool air through it
Minor mods to back of bumper required.<ul><li><a href="https://www.apikol.com/index.php#products,Kool">Apikol FMIC</a></li></ul>
BlackS4tt (Josh)
13
10-30-2006 02:20 PM
jeff28
11-29-2001 10:23 PM
LessCode MoreBeer
08-24-2001 09:52 PM
