Alignment question / Tire wear issue
Out of pure luck I noticed that the inside edge of my left front tire was worn to the cords.
<a href="http://photobucket.com/" target="_blank"><img src="http://img.photobucket.com/albums/v687/MAtkisson/l_tire.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
My right front tire does not show even close to the same amount of wear as the left.
<a href="http://photobucket.com/" target="_blank"><img src="http://img.photobucket.com/albums/v687/MAtkisson/r_tire.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
I just bought a full set of tires (at the recommendation of a few members here)
<a href="http://photobucket.com/" target="_blank"><img src="http://img.photobucket.com/albums/v687/MAtkisson/new_tire.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
After new tires I had my alignment checked.
<a href="http://photobucket.com/" target="_blank"><img src="http://img.photobucket.com/albums/v687/MAtkisson/alignment.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Do any suspension experts see anything on this printout that would have caused the excessive wear on the left front?? Is there anything in the "after" readings I should be concerned about for uneven tire wear??
-1.6 degrees of camber on your left front was the issue
they put you down to -1.2 which is the very outer acceptable limit (-1.1 with a max variation of .1).
Is your car lowered? Are you running modified camber plates?
New bushings all over the whole car, or a better place to do the alignment...
When I go get my car aligned; I know them, they take their time. Usually while I'm there, I help, I'm involved. Also they do about 2 cars in the other stall in the time it takes to usually do mine, only cause I want it right!
Re: Who aligned your car? Mine is LOWERED, and I think has better specs in the after!!
Since I live in a really small town (11k people) there aren't too many alignment shops around here. I had the car aligned at Les Schwab.
