Anyone know where to get a coolant hose kit or have the P/N for the coolant line to the turbo?
I STFA and found that kits are available, but not where to get them. I haven't had any luck finding a kit online. I want to replace all my coolant hoses and fittings and I'm betting that a kit is cheaper than ordering everything individually.
I found an extensive list of coolant system part numbers posted by kday, but I'm still missing the number for the turbo coolant line under intake manifold. Is there anything in this list I've missed? I intentionally left off the after run pump, coolant reservoir and hoses to the heater core.
034121063 Cooling/Coolant Hose; Coolant Pipe to Block (Pump)
443121321 Radiator Cap/Expansion Tank Cap; Female Thread; Round
4A0121055C Radiator Hose; Lower Thermostat Housing to Water Pipe
4A0121055D Radiator Hose; Lower Radiator to Water Pipe
4A0121081 Cooling/Coolant Hose; Cylinder Head Pipe to Auxiliary Water Pump
4A0121082 Cooling/Coolant Hose; Auxiliary Water Pump to Water Manifold
4A0121101B Radiator Hose; Upper Radiator to Cylinder Head to Expansion Tank
4A0121109A Expansion Tank/Coolant Reservoir Hose; Bottom of Expansion Tank to Water Pipe
4A0121109B Cooling/Coolant Hose; Radiator to Water Pipe
035121113B Thermostat 87 degree
034121143E Coolant flange on back of block
N90035103 O-ring for coolant flange on back of block
4A0819497 Tee fitting on back of block
N90316802 O-ring for sensor in T fitting
4a0 819 371 B hose, flange to tee
If I can't find a kit I'll just order everything listed above plus anything you guys can pick out that I missed.
I got mine from SJM for $14 including clamps.
I don't think there is a kit anymore, but Blau used to sell one, but it wasn't as extensive as your list.
034121143E is not coming up when I search for it at online parts suppliers. I'd really like to get the metal version of this part from the 10v or 3B if I can find the part number for it and it is still available.
The 3B and MC one is the same but without the E. Not sure if it is metal or not.<ul><li><a href="http://www.worldimpex.com/search_by_partno.html?searchmode=partno&partno =034121143E+&x=58&y=4">http://www.worldimpex.com/search_by_partno.html?searchmode=partno&partno =034121143E+&x=58&y=4</a</li></ul>
68jcode
12
09-21-2009 06:17 AM
politicallysavy83
04-11-2007 09:36 AM
quattro-sport97
12-11-2005 05:00 PM
kday
Audi Original "S" Cars
08-31-2005 05:45 PM
