is the belt driven fan in front of ps pump supposed to run all the time?
replaced fan clutch last summer, could this fan e causing to much cooling at temps below 20f
Neigher of the fans can cause too much cooling. If the engine is running too cold there is a problem with the thermostat. If it's stuck open the engine will not heat up to the proper temp.
this is my best assumption. I know the wires are good to the gauge because it does work.
S4 in_lowplaces
06-27-2007 12:07 PM
audikyle98
02-04-2007 12:11 PM
fkess
08-09-2005 08:34 AM
