With the body shop topic on the table...Anyone ever replace a rear quarter panel?
They are the same as a C4 100 correct? I want to replace mine and I am not sure how to remove them. I am pretty sure they CAN be removed and not cut out.
Thanks
Thanks
and has to be cut out and welded back in place.
This is just what I have heard over the years of ownership though, no first hand knowledge.
part numbers 4A5809601A and 4A5809602B. If they get cut, it in the lower rear door jam and in back by the lower edge of the trunk. Still curious of how to do it.
Is yours bad (previous body work or rust)?
It is usually better if it can be patched and saved if body shop person is talented. If removed and rewelded, anyone looking under the carpet in the trunk will readily be able to tell.
in the back at the rear facia.
Can be complicated, but can be done. Its the resulting finish a lip in the door jamb and with no seam sealer or non-factory looking seam sealer that gives it away.
I saw pictures of the restore process and I know the shope that did it. The car looked fantastic when I bought it 8 years ago. But the Vermont winters have been rough on it and the rear wheel wells have some rot from the last few years. I'd rather replace than repair. My friend and I are going to be doing the work so I have a bit more flex ability in the way of cost. He has a full body shop and paint booth at his place in Tennessee. He is amazing with autobody, been doing it for 15 years or something. Right now just on the side as a hobby. I have very limited experience so it should be fun and educational. Right now I am collecting parts and supplies.
That way the cuts are in tucked away areas and there's less potential of future porblems on the wheel well. The rot right now is because the edge of the metal got sand blasted and moisture got under the filler they used during the original job. The filler bubbled with rust and flaked off. Looks like *** right now.
and it is getting very exciting! Can't wait for the real work to begin.
