Bonus: 7A versus AAN. Who has the omega pan?
On the top you see an AAN oil pan. On the bottom you see a 7A oil pan. Both have almost identical baffles, but the 7A actually holds more oil thanks to its kangaroo side pouch. Could this be an upgrade down under?
<img src="http://pictureposter.audiworld.com/67654/cimg2917.jpg">
When I pulled the 7A from my 20vt coupe I pulled the pan off that didn't have the "Kangaroo pouch", but it did have this!!
Add the windage tray with two oil pan gaskets and you have quite the stationary oil!
<img src="http://pictureposter.audiworld.com/2752/100_1225.jpg">
Perfect for those hard rights!
The stock 7A pan has a tray which I removed for the picture I posted so you could see the baffles. It also has a boss on the front of the pan that the AAN doesn't have. This has to be cut off to install a 7A oil pan on an AAN or else it hits the harmonic dampener.
<img src="http://pictureposter.audiworld.com/67654/cimg2921.jpg">
RxFX101
12-10-2021 05:42 AM
JimmY@RojoCollisioN
08-23-2001 12:07 PM
