Brake master cilinder is leaking steering fluid
Hi, my brake master cilinder is leaking steering fluid thrru a small hole beneith, right on top of the brake boost preasure switch.
Anybody knows if there is a retainer somewhere that separates both brake and steering fluids?
tks
tks
Check the rubber grommets that seal the reservoir to the Master cylinder
/......... strange that my 1993 was leaking at said junction. easy enough fix by R&R the donut rubber grommets.
Just a thought.
JP
Just a thought.
JP
Re: Brake master cilinder is leaking steering fluid
I think here is my leak problem....i will take it out today and check....
http://www.autohausaz.com/search/product.aspx?sid=ljai0ya5fjbg1tj3uivcjezw&make id=800002@Audi&modelid=1009370@S6%20TURBO& year=1995&cid=14@Brake%20%26%20Wheel%20Hub& ;gid=1881@Pressure%20Accumulator%20Sphere
