Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Can a bad ignition wire cause the ecu to die?
Old 12-10-2005, 12:09 PM
spiralsmurf's Avatar
Default Can a bad ignition wire cause the ecu to die?
I was swapping OE coils on Black UrS6's car last night and we had everything running until for torqued down the coil cover fully.
after that it only cranks and doesnt run. Is it possible for the ecu to be damaged if spark shorted to ground? Where are the ECU fuses so I can check?
None of the wires are exposed, but there is one or two small spots where it split. I would imagine with that kind of voltage it would jump even w/o making contact.
Old 12-10-2005, 12:46 PM
pearlurs4's Avatar
Default Not very likely...
My car looked like it had a wiring job done by a 5 year old kid. The car was missing bad at high rpm's, once I re-wired everything there was no more issues.
Old 12-10-2005, 12:48 PM
Tech Guru
4Driver4's Avatar
Default You probably pinched one of the wires to the coil packs and shorted it out.
The fuse to the ECU is blown.
Old 12-10-2005, 12:54 PM
Junior Member
BlindBatForumFailer's Avatar
Default Also-
It briefly fired on 4 cyls, then died. Now won't fire at all.
Old 12-10-2005, 12:55 PM
Junior Member
Default Can we just replace fuse
should it fire right up or do we need to re-do wiring that was pinched?
Old 12-10-2005, 01:03 PM
Tech Guru
4Driver4's Avatar
Default Gotta fix the problem first, or the fuse will just blow again.
Those wires get very brittle.
Old 12-10-2005, 01:47 PM
seems promising...i'll check the ecu fuse when i get home at 5:30
Old 12-10-2005, 01:48 PM
where is the ecu fuse?
Rocket SLC
9
03-05-2021 09:09 PM
toothandnail
11-30-2008 11:18 AM
zola1
Inline-5 Discussion
11-11-2008 03:48 AM
UrS695
13
08-07-2007 03:02 PM
spiralsmurf
12-10-2005 09:14 PM
Quick Reply: Can a bad ignition wire cause the ecu to die?
