Can I build an "AAN" without having an AAN? For example,....
2.5 L block from a transporter
(rods and pistons to match)
Modified 7A head from 034
(Cams ???)
EM from Javad (or real RS2)
Intake and throttle body --- scrounged AAN
Flywheel and clutch - aftermarket
MAF I have
Injectors I have
ECU I will have
Harness I will have
What else??
(Cams ???)
MAF I have
Injectors I have
ECU I will have
Harness I will have
What else??
the motor I built for my 4ktq started life as an NG (10v NA 80/90q motor) short block married to a 7A head.
Thats the 'uber cheap' way to build a 20vt, since the resultant compression ratio is around 8.5:1
custom rods and pistons are an option too, of course...
Also, I would recommend a 7A FW as well. It's lighter than the AAN unit, not as light as an aluminum chatterbox, and fits fine with a 7A pilot bearing.
get in touch with ron aka itsaV8 here on audiworld. he has all the parts sitting in his garage and is/was pursuing this route...definitely knows all the requirements.
