Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Completed 1.8T coil conversion and suspension overhaul
Old 08-12-2006, 10:36 AM
bar1's Avatar
Default Completed 1.8T coil conversion and suspension overhaul
Did the coil conversion.. the car is running smoother than ever..
Also used last weekend to change most of the rubber ++ in the front:
2 x front/2 x rear yellow Koni
2 x front/2 x rear springs
2 x new control arms complete with new bushings (inner and outer)
2 x inner stabilizer bushings
2 x front/2 x rear subframe
2 x engine mounts
2 x transmission mounts
2 x outer CV boot kits
Car handles bettter than new now even if I didn't go the lowered suspension route.. (because of the bad roads here..)
Old 08-12-2006, 11:48 AM
Junior Member
closed loop's Avatar
Default How did your Trans and Engine Mounts look?
I have all of what you mentioned ready to go on my car except the trans and engine mounts, and wonder if I should just do those as well.
Old 08-12-2006, 12:00 PM
S6 4RiNGS's Avatar
yes I would. even snag a solid snub mount from 034.
Old 08-12-2006, 02:38 PM
UrS4boy's Avatar
Was the 1.8t coil conversion a DIY and, if so, how did it go?
Old 08-13-2006, 12:32 AM
bar1's Avatar
They looked ok and I can't say changing them made any difference..
Old 08-13-2006, 12:36 AM
bar1's Avatar
Yes DIY, followed your description in the coil conversion document and used Volvo connectors.
Old 08-13-2006, 07:09 AM
UrS4boy's Avatar
Good for you. 115L or 115R coil packs?
Old 08-13-2006, 07:19 AM
bar1's Avatar
115L
Old 08-13-2006, 07:39 AM
UrS4boy's Avatar
Default I hope you pointed No. 5 to the front of the engine. (And looped the...
wires around like I did). Pointing them at the firewall seems to induce more heat into them (maybe through the wires touching the cam cover), causing premature failure. (3 cases so far - all no. 5).
On an unrelated note: I think your car is an automatck (IIRC). What are the letters following the ECU part No.? "AA"?
Old 08-13-2006, 08:22 AM
bar1's Avatar
Default I did. The layout is exactly like yours.
Yes it's an autotranny. Completely stock. Where do I find that number?
Quick Reply: Completed 1.8T coil conversion and suspension overhaul
