Concensus on running an 044 fuel pump on stock injectors/ECU
Long story short, I gotta get the car up to the shop for them to install the 044 pump on it, and I will be running it on stock injectors/fuel pump to get it there, and I really don't want to get into having them change out the injectors at the same time/mess around with the VEMs to calibrate it for running 60 lb/injectors...so is it safe to run the 044 fuel pump on stock injectors and stock engine management? Looks like Kevin Day does...
BTW, if you run 60 lb injectors and an 044 fuel pump on stock managament then you will ruin all your spark plugs, BTDT.
k04/rs6north
40
09-20-2006 06:32 PM
paulpas
03-26-2006 08:06 AM
Shaun@SG
12-12-2002 07:05 AM
