In cruise on the highway, roll-on slighty to pass and get CEL and boost limited
I pulled the codes and got an adaptation fault and a 540 G66 Knock Sensor intermittent. I assume the CEL is from the knock sensor as I have had the fuel adaptation fault before. Fault went away on rekey. Anyone else ever have this? Thanks.
Different car/engine, but my 4ktq did the same thing after I chipped it. Barely hit boost = CEL.
Codes revealed the knock sensor was the culprit.
starts detonating at 5-7psi boost, right? I get the same code, for the 1-2-3cyl knock sensor. Problem is, the sensor was replaced last year. Let me know if you end up replacing the sensor and if that fixes it.
It has happened twice now and only when driving home from work in the afternoon. It goes away on a key cycle. Will still pull 22psi when driving hard, and the code seems to set when just cruising on the highway. I will keep an eye on it. Can the VAG-Com monitor knock sensor output?
smcg3
03-16-2009 10:29 AM
clinton c
01-03-2009 11:34 PM
Too Cold NB1.8T
VAG-COM Discussion
11-20-2005 06:29 PM
