dash / cluster lighting wiring. (search not working)
ok correct me if i am wrong here but...
the light switch feeds power to the dimmer and the dimmer to the rest of the dash?
if so one of the pins on the plugs for the cluster must be switched positive when lights are on?
there is a fuse for the cluster lights and no relay?
i am trying to find why there's no lights in the cluster, did obvious check fuse, change dimmer on cluster check bulbs in cluster.
the thing i cant figure out is there's no power going to the cluster when the lights are turned on. the rest of the dash lights up.
so is there a relay between switch and cluster? or a bad switch/dead line to cluster?
that's the next step.
so i am not crazy at assume there would be a pin on the plug that would be switched positive to the cluster?
funny part is all the other lights work
and the fuses are all good, i spent some time in the cold checking them tonight.
jimmy154
06-22-2005 02:43 PM
Kirk
01-22-2002 02:25 PM
