Does anyone have a pinout for the rear defrost switch (6 pin)? TIA!
It has a built-in ~10 minute timer. So you'd get 10 minutes of mp3s and then have to hit the button again.
A fog light switch would be better. Best would be to somehow trigger the relay automatically when your aux device is turned on. I did that, but in my case I had an "amp remote" line on the mp3 head unit. Maybe there is a suitable signal on the iPod harness.
There is a signal on the dock connector that could be used to trigger the relay, but you would need a transistor to get enough current.
Some info <a href="http://ipodlinux.org/IPod_to_T%26A_remotecontrol_adapter#Short_descript ion_of_the_iPod_Dock-Connector">here</a> on the dock connector.
Run pin 18 to the gate of a FET, use the drain of the FET to switch the ground side of the relay coil. Presto!
part #4A0 941 503 (also took it apart to check)
switch with timer circuit is
#4A0 941 503F
#4A0 941 503F
turbos4audi
Audi Original "S" Cars
03-03-2009 01:56 PM
Nate (ETKA+Scumbag)
09-05-2005 06:11 PM
ForceFed
9
01-16-2004 12:22 PM
Dr. Bombay
12-08-2001 01:29 PM
