Engine/Tranny/Snub mounts. Fix a shifting problem?
My 1st gear is much better now with MT90, shifting isnt bad, but sometimes i "hit" somthing going into second or third, its weird and hard to explain but im thinking since my shifter will move a little with throttle somtimes that i need new mounts, maybe just snub? if i was to do the mounts is there anyway that shifting will be smoother? im just thinking maybe the tranny is moving too much when i shift and so im having a harder time?
Yes i did STFA, i found a good post, know changing them is easy and i know it will help my shifter moving, just nto sure about the shifting issue. thanks.
I'd say the $13 one is probably as good as the motorsport one (ya you save ~$7 bucks...), but you will still need to do what Adriano and I did to reduce the clearance... or you can opt for the 034efi kit that is professionally made and includes a new bracket but it's more dinero than our home brew solution...
"Sometimes I had some dificulty on shifting 1st gear to 2nd gear at WOT, now the 2nd gear "goes in" almost by it self!"
thats EXACTLY what im expiriencing omg... im so excited thanks so much!!
