The ever popular Oil weight question - again!
What would be the ideal wieght to use in the Pacific Northwest where the weather is pretty mild. Not too hot summers and not too cold winters.. I am running 10W30 synthetic blend right now and would like to venture into the full synthetic world.
So far, no leaks and no oil consumption as far as I can see.
TIA
TIA
TIA
TIA
Using 10w - 30 as an example.
The lower number is that the oil is the same 'thickness' as a 10 weight at 0°f, and the same thickness as a 30 weight at 200°f. The oil is thinner at 200° than at 0°, however.
To make a 10w - 30 out of dino oil, start with a thinner oil, say 5w, and add 'viscosity improvers' to get the desired results. (5w anything is downright horrid stuff.) These 'improvers' are not as stable as the oil part, or provide the same lubrication. Meaning, multiweights needed to be changed more often, and the 'wider the spread', the less oil there is in a quart. (Which is why a 10 - 30 is a better choice than a 10-40 in a high output/heat engine.)
With a synthetic, toss the whole 'improvers' theory out the window - they can brew up what ever they want - and it will all be lubricant. And a damned good one at that.
The thinner the oil when cold, the faster parts are lubed at startup. The thicker at full temp - the better for oil pressure. (BUT - robs HP!)
thomas alum
12-18-2004 02:24 PM
OCDaudi90q
06-02-2004 03:07 AM
YS4
08-15-2002 08:23 AM
